KMartinCPA1966's avatar
Apr 04, 2023
Some TV's get cable, some do not...WHY?!?!?
I'm usually pretty savvy about tech issues, but this has me stumped....
My Class A has 5 TV's, they all work, all get OTA TV signals, etc...
This week was the first time we tried to connect to the local RV Resort's cable...some of the TV's receive/process the signal fine, but 2 do not. I checked every option to include taking all TV's down and hooking them directly to park's outside cable. I EVEN BOUGHT A BRAND NEW TV... and it did not receive/process the cable signal either (returned it). It's not the Antenna/Cable option, it's not the cables, it has nothing to do with anything other than something must be different about how the sets are receiving/processing the signal. Tuner issues? Has anyone ever heard of this situation? I scanned the Internet and came across several who described the same situation, but ultimately were fed lines about splitters, new cables, etc. Please....these TV's were all hooked up directly to the outside cable...literally, you could unplug the coax from one TV that worked fine, plug it into a different TV (even the brand new one) and it wouldn't find a signal. If I had hair, I would pull it all out!!!
One of the TV's that receives channels is a Vizio D32f-F1...the brand new one that would not find channels (using the exact same coax staight from the outside box) was a Vizio D32h-j04.
Could it be an age thing? The Vizio that receives/processes the local cable is 2018 and the newer TV was 2023...would that matter?
  • Did you change the settings on the TV from OTA to Cable? Then do a serch for chanels?
    Bill
