STBRetired wrote:
One last thing. You should go through the setup menu for your radio and set the subwoofer setting to "off". With the subwoofer setting set to "on", the radio will route most of the lower frequencies to the subwoofer. Setting it to "off" will have the radio route those frequencies to the regular speakers instead.
Wilco. Never would have thought of that.
ON EDIT:
I went out to the trailer. It is a Clarion M303. In the menus, the sub-woofer volume is set to 0 (out of a range of -6 to +6) and the REAR/SW setting is set to REAR, not Sub-Woofer. That is what they were set at when I went out there. I hope that is what you were referring to.
