rickhise
Oct 03, 2017Explorer
Let me try this fix. When I pull the plate off
I see a splitter. One input two out puts.
If I take the black co ax wire. That I assume
It's the input
Attach it to the plate could one assume that
Will be a direct feed from the outside connector
Where the tailgater is hooked?
I understand this will disconnect antenna feed
an the other outlets
Making the only port hot is at the entertainment
Center
It's the input
Center
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
