rickhise's avatar
rickhise
Sportsman 281LRSS. 2016 help on tv cable
Sponsored By:
rickhise
home
Full Member
View Profile
Online
Posted: 10/01/17 07:11pm Link | Quote | Edit | Print | Notify Moderator
My factory wired tv cable system is useless.
If you have had any luck in figuring out how the manufacture, screwed this up
and a remedy please share
I'm assuming the cable connection on the front of the unit near the door entrance
Is a feed for an tv outside.
I have no manual and what I have found on line doesn't mention cable tv
Another cable connector on the rear of the camper,
I'm assuming that is the input for the dish.
There are 2 outlets inside the unit one by a hall way by the
Intertainment center an one in the bedroom.
Any thought s on how to see where manufacture dropped the ball.
* This post was last edited 10/01/17 10:52pm by rickhise * View edit history
  • Thanks. I'm trying to connect to a dish tailgater
    It works fine by direct wire
    The on off switch for antenna I'm not aware of
    There are 2 cable outlets. One on the outside of the camper one at end of the unit by spare tire.
    One beside the entrance door. I would think the one near the entrance door
    Would be for an outside tv, not sure.
    Inside the camper I have 2 cable outlets one above entertainment
    Cabinet, also one in celling in bedroom
    I have tried hooking to both inside outlets. Same result
    No incoming signal
    Note\On the wall plate by the entertainment center where you attach the cable
    That face plate where the cable attaches may have a switch on it I'll take a second
    look
  • find your tv wall plate with the on off antenna switch turn it on for antenna or off for cable then do a channel search from the tv menu screen and be sure to set it to scan cable channels for cable or air channels for over the air channels. that has to be done at each new location you go to. and on each tv. here is the manual for the switch you are looking for should be behind the main tv. tv wall plate says they include cable hookup on these sportsman
    Or perhaps you just are not using it correctly.
    What are you trying to connect? Park cable, Direct TV, Dish Network?
    Is the OTA antenna working?
    Please elaborate...
  • Rick I do not understand a few things.
    Are you connecting to the rear connection to get CABLE
    Do you have an antenna?
    If you have an antenna there should be somewhere to switch from OTA to cable.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
