Bobbo
May 27, 2020Explorer III
ford truck guy wrote:
Should I try to reverse the leads? red to black, black to red?
Don't reverse the leads unless you have proved that you need to. If you reverse the polarity on the Winegard, you may damage it. Take your multimeter up there and check the power again. Twice. Once with the red lead to red wire/black lead to black wire. Then again, with the red lead to black wire/black lead to red wire. When you get a negative voltage reading, then whichever wire is on the BLACK lead is the positive wire.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
