opnspaces
May 27, 2020Navigator III
ford truck guy wrote:
**UPDATE **
Winegard just responded to my email,, they said that it "looks" like the wires are just reversed somewhere in line... I will put the meter back on them later today when i get home from work. I will try red lead to black wire and black lead to red wire.. I SHOULD have a normal reading at that point..
Thanks to all.. I am not afraid to admit when i have no idea what i am doing... Thanks for the responses..
Correct. From what you have been saying it looks like the wires are crossed somewhere before the Winegard. But with one Caveat that we haven't touched since you say you are new to this. Are your leads correctly plugged into the meter? Because if the leads are reversed your readings are reversed.
Before you climb up on the roof take your meter and touch red to positive (+) and black to negative (-) on your battery and make sure you read +12 volts. Then climb up on the roof and ignore the wire colors. Once you find the combination that reads positive voltage the wire touching the red lead is positive.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
