RDMueller's avatar
RDMueller
Streaming TV in an RV using a cellular data plan
Background- we are not actually going to watch much TV when camping, just want to have the option if the weather is bad for example. We seldom camp anywhere with TV hookups. Could do satellite but I'm leaning no on that, probably just wouldn't use it enough to justify the cost. I haven't had much luck with over the air, most likely due to the fairly remote and mountainous areas we usually camp.
So far we've mostly just watched DVDs, but that's a slowly dying technology. I haven't purchased a DVD in a long time. Blockbuster is basically gone. Redbox is usually the best option, but even that can sometimes be fairly distant depending where we are.
What I'd like to be able to do is stream Netflix or Hulu. We have a 10GB cellular data plan with plenty left over most months. But how to get it from the iPhone to the TV? I have Apple TV at home, but that requires a home network which is connected to our cable modem. I can create a wifi hot spot with my iPhone, but that doesn't use a router and Apple TV needs the router to work. I'm pretty sure that Roku works the same way. I've been looking at Amazon Fire TV Stick and it looks promising (they say you can use it in a hotel). Has anyone used it? Will it stream from a phone with LTE? Any other good options anyone can recommend? Thanks!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
