pianotuna wrote:
My Brother did not listen to me. He ended up with a swollen battery on a MyFi type device from Bell Canada.
So the real answer is "it depends".
For LI I try to go 20% to 90%.
A "MyFy" device IS NOT the same as a Tablet or CellPhone, it is a dedicated Cell to WiFi device.. BUT YET, the swollen battery issue was most likely either a defective battery (was a rash of that a few yrs back) and or a poorly designed or defective battery management system.
CellPhone and Tablets or pretty much any other device which is designed around Lithium battery use are purposely designed with a battery management system which when properly designed controls charge and discharging of the Lithium battery pack.
The battery management only charges the battery when it is needed and controls the charging current, if battery is not discharged, it will not charge the battery and the device will operated directly from the charging port with zero harm to the battery or device.
What causes the most harm to Lithium batteries is charging or discharging when EXTREMELY COLD OR HOT environment (in your vehicle in freezing weather (32F or lower) or Summer time with the windows up and full sunshine (+100F or higher).
Rule of thumb, if YOU are not comfortable without a coat or in a speedo, your phone/tablet with Lithium battery will not be comfortable..
