12th_Man_Fan's avatar
12th_Man_Fan
Television adjustment
I have two VIZIO TV's in my rig and I can't for the life of me get the picture adjusted to fit the screen. I have used the four auto options without any luck.
I am sitting in Colorado receiving signal over the antennae and the picture is too big for the screen. I am watching golf and the guys putting the ball isn't even on the screen.
Other emblems and information run off the screen. Is there any way to fix this. I have tried everything I can pull up on the menu.
Thanks for any help.
Doug
  • my Vizio (about 5 yrs old)
    has a menu option that says 'wide'
    click on that and i get 'screen mode' with (4) choices
    normal, wide,zoom,stretch
    mine is set on Normal
    now question time
    you are on antenna, antenna into TV
    or antenna thru Sat dish reciver
    might be nessceray to set the sat reciver output ?
  • It sounds like you don't have the correct resolution set and the issue is not with wide or stretch or normal.
    I looked through my Visio menu and I can't find what I am looking for but I do remember there being an option somewhere.
  • On my vizio it is the screen resolution, or size, I don't remember, but it is not the picture adjustment.
  • as Ross Perot said, "I'm all ears".
    my TVs at home do the same thing, go thru the panoramic, et.al. selections and it still cuts of ends.
    bumpy
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
