Ed_Gee
Mar 06, 2018Explorer II
The reason you are getting away with not using a controller is most likely due to the tiny size of your solar panel charge current compared to the capacity of your two group 31 batteries. You are charging at barely above trickle charge rate for your battery bank. Moving from a 65 Watt panel to 100 is not likely going to change much, either. If you plan on using both (165W) I suggest you do get a charge controller. 165 watts can output about 8-9 amps in full direct sunlight.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
