Ultrastryk's avatar
Ultrastryk
Total loss of picture on Satellite???
I have a 2012 Tiffin Open Road Pusher, with Dish hooked up to a permanent satellite on a pole during the summer. I was watching TV last night when the picture went totally blank as I was switching a light on over the couch. When I turn the sat receiver off and on, nothing comes on the screen. I checked all the connections, but I don't think that is the issue, as I would normally be able to get a setup or menu screen if it was just a loose connection. I tried a friends receiver, but nothing. I can switch over to antenna and I have a picture with that. Just nothing on satellite. Could I have a loose connection at the distribution box where all the cables come together before the final cable goes to the TV's?? I don't even know where that is on this coach. One of my earlier Tiffin's had that mounted on a frame rail underneath the coach. Anyone know where that might be on this coach, and would that make sense?
I didn't bother to call Dish, since I don't even get a setup or menu screen.
  • SCVJeff wrote:
    This may sound like a silly question, but have you turned that light back OFF yet?
    X2
  • This may sound like a silly question, but have you turned that light back OFF yet?
  • is the receiver box lighting up?
    no menu from receiver. receiver has died...
    menu will show if antenna/dish failed.
    call dish...
  • Dead LNB could do it. But you need to do a receiver reset then go through setup completely. If nothing happens, I guess you will need to try and find someone to come out and check your equipment
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Nov 18, 2025
