austinjenna's avatar
austinjenna
TPMS Question
I recently installed a TPMS system and was wondering what the high limit is folks used as compared to what their PSI is. So my trailer tires are at 80 PSI and noticed they went up to 89 PSI on the way home. How much of a rise is there normally in tires so I know what to be able to set the high PSI alarm on?
Thanks
  • The rise in pressure is due to an increase in temperature. Much more than a 10% increase in pressure could indicate you have a problem with a sticking brake or wheel bearing, so setting the high alarm at 10 - 15% over the cool pressure would probably be wise.
  • The rise will depend on the ambient temperature to a certain degree (HAR).
    Personally I don't worry too much about high pressure, but probably 10-15% rise would be common. I would be more concerned with low pressure, and high temperatures. Those are better indicators of potential problems.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Nov 14, 2025
