AKBOB's avatar
AKBOB
Trav'ler Problem
Hi,
I just sent this to Wineguard help desk but they are closed today. Thought I would post here to see if anyone has any ideas. Thanks.
I am in the middle of a trip and my Trav'ler is not acquiring a signal anymore. On Tuesday, May 5th I activated the Trav'ler, after arriving at a new RV park. The dish went up and the control box indicated the 3 satellites were locked on. But when I turned on the Dish 211K receiver it would report an error message of "complete signal loss". I tried many times to re-set all aspects of the system. From lowering and re-establishing a lock on the satellites with the Trav'ler to re-booting the 211K. All with no success.
After moving to a new RV Park a few hundred miles up the road on May 9th, I tried again. No luck. I called and spoke to Dish Tech support and after going through all their troubleshooting steps, they said it was the satellite that was not performing properly.
I decided to take matter into my own hands today. I connected a new coax cable from Port C directly to the back of the 211K to eliminate a cable issue. No luck, same issue. While up their I checked all coax connections and even looked at the connections at the end of the LNB. All looked clean and tight.
I borrowed a 211Z and still had the error message of "complete signal loss". I took my 211K to a home and connected it to their Dish system. My 211K worked.
So through process of elimination, something appears to be inoperable within the Trav'ler dish.
Since all the coax connections on the Trav'ler appear to be good, would the problem be between the rotating upper section and the base unit mounted on the roof of the RV? How do the coax connections connect to allow the upper unit to rotate?
This Trav'ler I have is a replacement unit you shipped to me the end of Sept. 2013 to replace my original unit for an unrelated problem. Now, less than 20 months later, I am dead in the water again.
I am requesting assistance in determining the problem and correcting it.
  • Did they actually tell you they don't test them in service? I can't possibly see how they can determine what's wrong any other way
    You cannot look at reflector or LNB alignment any other way
  • Uea, lots of then have worked very well. However the fact remains if there ever is a problem with them Winegard has no clue how to properly trouble shoot or repair them. Their idea if testing one is by a signal generator. They never connect them to power, ask them to lock onto the proper birds and then verify they actually can see the correct sats. Just plane sad to me. It took me nearly three months of constant working with them, including over two weeks by a dealer service department, finally upper managment getting involved to get what should have been a relatively simple troubleshooting and repair job resolved. Winegard finally stepped up to the plate and did what was right,so yea, I was frustrated at the time. But now just feel their service department has to be some of the worst.
  • donn0128 I understand your frustrations because you had a bad unit but I disagree that they are junk. There are thousands of them working properly. In my case I was one of the early users of the SK-3005. Mine is so old that it came with 3 output cables instead of four as in the newer units. For over 10 years it has worked perfectly.
  • Yup, same as the 3005 except for dish. As I found out the hard way, they are junk! Cost me several hundred dollars, anout three weeks without my fiver before Winegard finally decided they did not know why even though it said locked on there was no signal. I personally went through the new coax directly from the LNB to the receiver with zero signal. This proved to me that the dish simply was not locking onto the birds regardless of what everyone said. I spent over four hundred dollars for shipping and another three hundred or so for Winegard to rebuild my system. It was returned to me and after reinstalling it it still had the exact same problem. Like I said the SK 1000, SK 3005 is junk!
  • Ill bet it is an SK 3005? Mine bit the dust in exactly the same way. Winegard could not fix it and eventually replaced it at minimal cost to me with a SK-SWM.
