rbreak's avatar
rbreak
Trouble receiving directv channels with hr24 reciever
Hello,
Being a complete newbie to satellite tv, I recently switched to directv in my home hoping I could figure out how to set up a system in my rv. I got the usual genie and mini genies for the house, and had them also bring an hr24 receiver to use with my older winegard roadtrip sat dish mounted on the roof of my rv. My first attempts were complete failures, but after much searching and reading for new things to try, I finally got a strong signal on the 101 satellite. I even got to the main guide page to pick the channels, and thought I was done. Turns out not so, most of the channels were grayed out and could not even be picked, and the ones I tried gave a message saying the receiver was not set up to receive these channels. I don't understand, I thought I should get all the same channels that I get at home? I get that some local channels won't work if your out of the local spot beam, but I was local and also many of the non working channels had nothing to do with being local. Well, I thought I was almost there. Any help, suggestions or information would be greatly appreciated. This sat tv deal has been quite the headache.
  • If your receiver has been activated, you will need to go through the satellite set up menu. Most importantly is to choose the correct type of dish for the RV. Probably an 18" single lnb. The receiver should do a test and recognize this on it's own. In the HR, this should give you the SD channels. You will only be able to get standard definition, which is on the 101 sat. also be sure you have the coax connected to the correct coax input, there are 2.There is also a button on the front of the receiver to set it for 480P reception, which is standard definition. Star with those. Chuck
  • x2 on Murphsmom's comment. Your Winegard Roadtrip antenna will only pick up SD channels on a single satellite at a time, regardless of the receiver. None of the dome antennas can do HD, you need the Winegard Travel'r if you want DirecTV HD.
  • I have DireCTV in the house. First set is HD with the HD box. Second set, in the bedroom is SD with the SD box. Both have their own dish. Both are different. I get ALL my satellite stations and local networks on both.
    When going to snowbird, for instance, I take the SD box with me in the RV. I have the basics in the RV...dish, strength meter, compass. Everything goes thru my passive switchbox. Of course, when out of my local "spotbeam", I lose the networks. No biggie. Just put up the antenna, push the "ANT" button on the switchbox and aim the thing. Then...go back to the "SAT" button whenever. No problems.
    Tell DirecTV nothing (why add any complications...they will want you to pay extra,(an "RV account")...but make sure you pay your bill on time.
  • The reciever is an HD Reciever. Do you have HD. This just happened to us, if you don't have HD, you'll need to change HD, "no" let's start here, DO U HAVE HD.
  • The Wingard Trav'ler is the only antenna that provides HD signals from the 3 Directv satellites.
  • Is your older dish an HD one? If it isn't, that might explain the grayed out channels. If you aren't set up to receive HD programming, those channels probably won't work.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,794 PostsLatest Activity: Mar 07, 2025
