- cjd10Explorer
GECTisMe wrote:
I know this is very old, but I just had the same issue and wanted to say thanks and it still works.
Thank you!
X2 - GECTisMeExplorerI know this is very old, but I just had the same issue and wanted to say thanks and it still works.
Thank you! - edatlantaExplorer III have the TST 507 and love it. I have 8 sensors so I can include my TV.
It sure makes towing a lot more relaxing without constantly looking back in the mirrors to see if you have rubber pieces flying out from under your trailer. - fj12ryderExplorer IIIThe TST seems to be a good unit so I'm glad you got yours working.
- dbblsExplorerI had to call TST to find out how to do it. My manual did not cover this either. TST said they always program the right front tire into the monitor.
- sidneyExplorer
fj12ryder wrote:
From the manual:
"In standby mode, press the "CODE" button for 3 seconds and release after the beep. The tire icon will flash and the relevant sensor code will be displayed. Initial code setting for all the sensors is "FFF FFF". In this mode press the "+" or "-" buttons to select the tire which needs to be coded or initialized.
Delete Sensor Code: In this mode, pressing the "SET" button for 3 seconds will initialize the sensor code to "FFF FFF"."
Hope that helps.
Thank you ryder... that worked.
I wasn't pressing the CODE button 1st... my manual reads a little different... it isn't very clear about deleting. - fj12ryderExplorer IIIFrom the manual:
Hope that helps.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,801 PostsLatest Activity: Jun 18, 2025
