wa8yxm
Oct 23, 2018Explorer III
Instead of installing a faceplate pop in a Sensar PRO..
On the sensar pro all the cables are labeled (They are cables behind it for assorted reasons)
YES one of the cables should go to the roof. YOu are gonna have a bit of fun identifying it if you do not already knwo or remember
Looking at the wall plate from the rear.. With teh 12 volt outlet at the TOP the cables are ANT (teh one you are looking for) CABLE (The one you run to your sat receiver) and TV-2 (The remote TV)
IF your Sat Receiver has coax TO TV hook that to the CABLE cable on the Sensar Pro.
ANT goes to the roof (I will give you a course in cable iD shortly)
TV-1 and TV-2 go to televisions, does not really matter which.
Cable ID
Go to the antenna and DISCONNECT the cable from the head.
IF YOU HAVE A PARTNER.. take an ohmmeter to the roof. hook between wire and the sleeve wher ethe nut connects. Careful not to short. Should show OPEN CIRCUIT.
Have partner short the connector inside and it should go to near zero if you have the right cable.. "Blink" the short a few times the meter should track
NO PARTNER
Well then short the top and look for the shorted cable below If you only have one.. Remove short to verify if short goes away re-connect and label "ANTENNA".
OH. Sensar PRO operation
OFF Push top button till all lights go out) Selects CABLE IN (or as I advised above Sat if it has RF out . NOTE If it does not have RF out then leave Cable not-connected)
Any other position (With any led lit) is ON (Rooftop antenna)
Top LED is "Search" it finds the strongest carrier displays the carrier channel number below and strength above You can rotate to peak
NExt spot the two bottom buttons (UP/DOwn) let you page through the carriers it found
Next you get to manually specify a carrier.
next is GAIN
Next is VOLUME (It has a Beeper like those sat finders or a sat receiver in AIM) and Then we are back to OFF. Top button changes mode.
My setup.... (Different than above)
Sensar Pro feeds a pair of DIgital TV converters which feed an old analog DVR (2 one for each) via A/V in.. Park cable feeds the ANT in on the DVR's so they can record off Cable or OTA.. if I had a Sat receiver.. well the DVR's have two A/V in so I'd be able to do that. A Computer process electronic program guides and serves 'em up and based on the "Channel number" the DVR"s choose ANT or AV/1 or AV/2 so they can record off all 3 sources without me needing to touch anything but the "RECORD" button..
OH the computer lets me do that from my Laptop as well.
Cable ID
NO PARTNER
next is GAIN
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
