Ron3rd
Nov 06, 2014Explorer III
Sifter wrote:
Looked through the install, not as bad as I thought. Guess I need to see how the existing base and this new base compare in size to determine if any patch work is needed.
Installation Manual
The hardest part would be running the cable, which you already have there. Basically all you need to do is drill a hole to the inside to mount everything up. Should be a fairly simple job.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
