1Longbow's avatar
1Longbow
TV Antenna
What would be a good replacement brand for a plain old over the air antenna for the RV. Just your old standard RV antenna. Thank you
  • Ours does not crank up its stationary and only points in one direction. Its real low to the roof. would the Wineguard fit on that post?
  • Winegard Batwing with the "fingers added." We had one of those little omni-direction things to replace a bad winegard and the little round one was not worth 2 cents. Would not do that anymore.
    Would replace top portion of Batwing only if crank up part is still in good condition. Also, I used silicone grease on all moving parts on one of my rvs every year or so.
    Winegard Batwing
  • WILDEBILL308 wrote:
    Do you have a Wingard Now? There is an add on part to make it for high definition/ digital.I think they call it, Winegard RV-WING Wingman White UHF Booster TV Antenna You can get it on Amazon. Or by the whole antenna. I included a link to wingard.
    http://www.winegard.com/sensar
    Bill
    The Wingman add-on does not make the Sensar (batwing) "high definition/digital", it does increase the signal gain of the built-in UHF antenna section though. Even an old pair of rabbit ears or a paper clip is capable of receiving "high definition/digital" programming if the signal is strong enough. Radio signals are radio signals...
  • RoyB wrote:
    I think most folks on here are going to tell you it is hard to do any better than this BATWING Crank-up Antenna with dipoles on it...
    Google Image
    Roy Ken
    Absolutely! Nothing better. Most issues with the Batwing are related to corrosion at the connections due to water intrusion.
  • Do you have a Wingard Now? There is an add on part to make it for high definition/ digital.I think they call it, Winegard RV-WING Wingman White UHF Booster TV Antenna You can get it on Amazon. Or by the whole antenna. I included a link to wingard.
    Bill
  • Winegard Sensar IV is about the best, if your mast is ok, just replace the head.
  • RoyB's avatar
    RoyB
    Explorer II
    Google Image
    Roy Ken
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
