LannyV
Nov 23, 2016Explorer
Verizon "Home Phone"
Does anyone use Verizon's or AT&T's "Home Phone" in their RV from their RV batteries and not an AC inverter? The reason I am asking is I have encountered a problem using a Verizon “home phone” along with a cordless phone. Briefly when I use the “Home Phone” (a wireless phone provided by Verizon and AT&T) connect to a cordless phone in my house with both running on their own 120 volt ac wall warts all works fine. I want to take this along with me in the RV and want to use it on the vehicles battery system. The “home phone” is 12v DC (direct plug into 12 volts in RV) and the cordless phone is 6.5v DC (convert 12v to 6.5v adapter). The “home phone” and cordless phone are tied together with the standard 4 pin RJ-11 connector. What happens when I try to run both on DC with the proper voltage adapters, is I get no dial tone. I am assuming this has to do with the tip and ring function. Now to get around this I purchased a 12v isolation power supply and use this to plug my 12v to 6v convertor into. By isolating the ground between the two it works fine, just like at home. I would like to do away with the isolation power supply and not use an inverter. I am looking for suggestions as how to do this. If you are running a similar setup on your battery system without any problems what brand of cordless phone are you using?
Thanks
Thanks
