MrWizard
Jul 28, 2019Moderator
when its working early in the morning, log into the jetpack itselt
and pull up the signal level, connection info or diagnostics menu
see what it is
then do the same thing again again after the problem starts
see if you have the same signal strength
if signal is significantly lower/different (large numbers 105 mean weak signal)(low numbers 56 mean strong signal)
could indicate work on the tower
or some kind of interference or tower overload
see what it is
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
