edatlanta
Aug 22, 2019Explorer II
Two days ago we had a pretty strong thunderstorm passed through here and the Verizon tower that serves my area was right in the middle of it. During the storm passage one of my 3 Jetpacks quit working or should I say slowed way down. I looked at it and it was roaming on 3G and AT&T. All three of my Jetpacks are in the same area about 8-10' apart and the other two were operating normally on Verizon 4G LTE. I rebooted it and even took the battery out and rebooted with no change. It booted back up to AT&T 3G and 1 bar. AT&T does have very poor coverage in this area, but why did this one Jetpack switch to AT&T?
I went into the configuration settings and looked at the network options and sure enough it was set to AT&T. I changed it to Verizon and now it is working normally again.
On another note I have an Amazon Fire Stick. The first time I used it after the Jetpack issue I noted the captioning was in Russian. I had to change that back to English.
Electronics? Go Figure!
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
