dryfly's avatar
dryfly
VPN question
I am considering build a Virtual Private Network for remote security camera viewing. I don't want to do basic port forwarding for security reasons.
I have found that VPN's can be hardware such as in the router, software in the computer, or through VPN service providers. As far as I can determine these providers act between a LAN and the ISP.
Question: which would be the most advantageous, and most economical?
  • Mortimer Brewster wrote:
    I do have to reset the connection once or twice a day when it loses connectivity. Hope this helps.
    Is this normal with PIA? If so, that would rule it out for me, as my objective is remote access. I could not do resets effectively.
  • I’m no expert, so I can’t say what’s best for your personal use. I use a VPN service provider, PIA VPN. It allows me to use public WiFi more securely. Some use it to help watch European sporting events. To do so might require you to set your location somewhere in Europe.
    The paid VPNs are supposedly better than the free ones. PIA VPN is normally $40 per year, though it does occasionally go on sale. I do have to reset the connection once or twice a day when it loses connectivity. Hope this helps.
  • The use of a VPN is to keep the rest of the internet out of your system
    A Router etc.. Is still using software, that is built in, to connect to some provider
    If this is for security cameras etc..
    Then go any which way, it really won't matter too much
    If this is security for your pc and your network your browsing
    Then Google VPN compare, and choose the service you like the best
    There are a lot of options
    A good high rated paid service is probably the best
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Oct 16, 2025
