boston_blacky's avatar
Sep 23, 2016
What to do next?? Is it malware or not?
Two (2) days ago I was doing nothing unusual just routine stuff on the internet when this happened! A pop-up from nowhere prevents me from deleting it and going forward or back. It says something about calling their 1-800 number - and learn more about this issue / from S3.AMAZONAWS.COM, etc. etc.
Could not get pass it - like I said or go back. Deleting it didn't work - as all I could hear was a load click!! as each attempt to delete.
Best Buy greek Dude said nothing could be done, as it would only come back; i.e. unwanted 'pop-up'. Has anyone found a solution for this?
If so, please let me know. Thanks in advance.
  • JnJnKatiebug wrote:
    Next time that happens hit Ctrl-Alt-Delete and your task manager will pop up and show you what is running. Right click the browser and hit close. Then run your CC cleaner. If you don't have CC Cleaner I would suggest you download it and run it every time you leave the internet.
    And if you do not have CC Cleaner once you can navigate in task manager
    go to the startup tab and delete the program that is causing the problem.
  • Next time that happens hit Ctrl-Alt-Delete and your task manager will pop up and show you what is running. Right click the browser and hit close. Then run your CC cleaner. If you don't have CC Cleaner I would suggest you download it and run it every time you leave the internet.
    If you cannot close or back out of a window, it can be closed from the task manager.
  • Plenty of google hits on that. Hope you can get pass it.
  • If the Geek dude can't or won't do anything or help you, I would find someone else quick. Any decent geek should be able to handle that type problem, and make sure it didn't come back again. BTW, I'm not a decent geek, just a fumble-fingered weirdo.
  • S3.AMAZONAWS.COM is a URL leading to a cloud-based storage solution sold by, yes, Amazon. Who is it using that storage? That's the question.
    You say that you were doing routine stuff on the internet. Did that include visiting any adult or gaming sites? Those are targets for hackers to place malware, which your web browser then downloads.
    You might be able to get rid of it by running something like MalwareBytes and/or Spybot, then a full virus scan from something like Avast. Those would be the first things I'd try.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 28, 2025
