whizbang's avatar
whizbang
Explorer II
Sep 04, 2023
Wifi a long way away from RV site.
A lot of campgrounds and RV parks have "wifi at the office" but not in the park. Is there a long range receiver, booster, or antenna that allows one to get the signal from a campsite?
15 years ago, I bought a range extender that actually did this. It worked great until 5G came out and security protocols changed. I just did several online searches for wifi extenders, boosters, and antennas, and, all I can find are products that allow one to TRANSMIT wifi further. I want to RECEIVE wifi from further away from the source.
Can you recommend anything???
  • I have the system in this thread
    David Bott Tutorial
    I haven't used it for the past several years because we have had good coverage on our Visible and Verizon phones. But it did work well when I used it. I mounted it on a PVC pole I bungeed to the ladder on the back of the coach. I could point it toward the access point, the ethernet cable ran inside to the wifi and power supply. Mine was only for 2ghz, but I think the new models are also 5ghz.
  • In the time before tethering from a phone worked well, I used the Alfa network adapters. Usually purchased from Ebay suppliers. Not only do these run a transmit power that is multiple of what ever, but the receiver sides are equally as good and I have some high gain antennas that can be aimed at the source.
    I still use them sometimes if I get in a position that I don't want to burn phone data.
    Matt_C
  • 5g cellular and WiFi are not related in any way. There are antennas that will help boost the incoming signal and amplify the out going but it still won't help if the campground service is overloaded as usual.
  • I recommend planning for your own internet and not rely of any public or park. Cell phone, cellular hot spot, or even satellite are the typical solutions.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Jul 27, 2025
