4x4FF's avatar
4x4FF
Wifi antenna ideas
I am wanting to put a wifi antenna/repeater on my 5er. I already have the router and omi-antenna. I don't want to use the 'USB Solutions' because I am a techy redneck and want to have multiple devices connected easily hence with a repeater I will create my own wifi network that I can connect to the campgrounds wifi.
With that being said I an debating over where and how to mount the antenna. I have seen some who have mounted it to their crank up antenna and fished the wire to a cubby up front. I really like that idea but I can see fishing the wire to be a little problematic. There is no access to the 'attic' between the antenna crank and the cubby. Especially with the thicker antenna wire I think this would be difficult but I'm still open for suggestions.
My second idea is to mount a pvc pole on the rear ladder with a second pvc pole inside it that I can use to slide the antenna up and down. This approach makes sense to me because the entertainment center is in the rear of the coach and that is where I would prefer the router to be located. My concern is if I use the LMR400 cable for the antenna to avoid signal loss, where do I store the extra cable when I retract the antenna???
I've been perusing the net searching for ideas and am just not sure which route is best. I'm open for suggestions.
Thanks,
Steve
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
