wa8yxm wrote:
Generally.. YES.. Or you can use the browser on your phone or tablet.
Oh, and I strongly suggest a DIRECTIONAL antenna (more range in the on-axis direction)
How I do it when I am at a campground NOTE this is for WI-FI.> NOT CELLULAR DATA
The
Ubiquiti Network products like the NanoStation that WA8YXM is decscribing are a great way to utilize park WIFI. I used the
Bullet instead on a 8dbi omni antenna attached to my crank-up TV antenna. No doubt a directional set-up would outperform the omni antenna but still works well enough to do as intended and is very simple to deploy. Unfortunately, the Ubiquiti solutions are not terribly user friendly to those who are not familiar with basic networking.
For a quick connection with slightly limited performance, I have available in my arsenal a
AmpedWirelss Range Entender attached to an exterior omni antenna. The set-up wizard on this product is very simple to use and no other equipment is needed if preferred. Again, not as performance oriented as the Ubiquiti products but, WAY easier set-up for many users without the desire to set-up their own network. In most parks we have been in, this is all that we need. WIFI is line-of-sight and getting that signal up and away from obstructions is huge. I am nearly 18' up to the tip of my omni antenna. For a quick lunch break or fuel stop and break, very easy and quick to deploy and enjoy WIFI at times.
And to answer the OP's question, all I use is the browser on my phone to make the connection.
