- sherlock62Explorer IILike many forum threads here, this thread has gone a muck so to speak. Regardless, do know that a WiFi Extender is a way to go if you need to extend a network. No, not a perfect solution, but it will more often then not, get very usable WiFi to an area where without the WiFi Extender, you would not have WiFi. I know quite a few people thrilled with their WiFi Extender. Sure worth a try for those with WiFi dead spots in a dwelling.
To "usermanual" you would do far better posting a link to the source of the crapola you post here. This way thread readers can read for themselves. - valhalla360Navigator
DutchmenSport wrote:
If you are able to tap into a campground WIFI and extend the range, then you better believe everyone else around you will be using the same signal from your extender too, slowing it down even more, as campground wifi's have the known reputation of running horrible when so many attempt to connect all at the same time.
Only if you leave the extender non-password protected. - usersmanualExplorer
Fizz wrote:
usersmanual wrote:
I am not trying to tell you anything;; NETGEAR;; them selves very clearly state in the instructions that your response time will slow when using this product that's all I posted
This sounds like "A glass half empty" look on life.
My main router gets me 75 Mbps but I only get 4 Mbps at the far end of the house.
The Extender gets me 28 Mbps, it's not near the 75 but a heck of an increase over 4 Mbps.
You can look at it as a drop from 75, to me it's an increase from 4.
its not a look on life at all;; its what the company that make and sell claim;; they claim it will slow your computer down when using this item what part of that do u not understand - Bill_SatelliteExplorer IIGo here:
http://tiffinrvnetwork.com/forum/viewforum.php?f=111
and do a search for WiFi under $100 and you will come up with the link to David Bott's video on how to get a powerful connection for less than $100 (or a bit more for the upgrade which I highly recommend).
This IS IT! - BB_TXNomadIf you are trying to get stronger wifi signal from the RV park, keep in mind that stronger signal will not necessarily mean faster speed. Not uncommon to have strong park wifi and still have very slow speed due to limited bandwidth.
- FizzExplorer
You can look at it as a drop from 75, to me it's an increase from 4. - usersmanualExplorer
Fizz wrote:
usersmanual wrote:
the big downfall to this cheap fix is it slows down the download/upload speeds by a lot
its a warning right in the netgear set up instructions
Don't know what you're trying to tell me.
I did a speed check on the iPad everywhere I tried it.
At the main router in the back room I get a solid 75 Mbps
In the front room I get 4 Mbps
With Netgear Extender I get 28 Mbps everywhere in the house
When I sit in the back room I switch to the main router.
Iam not trying to tell you anything;; NETGEAR;; them selves very clearly state in the instructions that your response time will slow when using this product that's all I posted
what Dutchman also postedBest Buy and talked to the folks there. The guy who helped us explained, that even though the range of WIFI is extended, the upload and download speed was considerably reduced ... like 50%
- DutchmenSportExplorerWe looked into getting a Netgear WIFI extender for the house. We went to Best Buy and talked to the folks there. The guy who helped us explained, that even though the range of WIFI is extended, the upload and download speed was considerably reduced ... like 50%. Thats no problem if you are using static web pages, but for streaming video or gaming, it could cause too much of a slow down.
We didn't want that, only to find out once we returned home (with new laptop's), that our Netgear wifi router was Dual Band. When we connected to the 5G band on all our devices, everything started running, like .... WOW!
Glad we talked to the guy first, and he had us take a second look at our current router. He's the one that explained to us how the dual band router works.
Turns out, our new television in the camper now pick up our WIFI great at home, as does our computers and every thing else, even in the camper, parked in the drive way.
Now... if the OP is looked for a way to extend campground WIFI, or a WIFI that he does not own, that's a different matter.
If you are able to tap into a campground WIFI and extend the range, then you better believe everyone else around you will be using the same signal from your extender too, slowing it down even more, as campground wifi's have the known reputation of running horrible when so many attempt to connect all at the same time. - sherlock62Explorer II
usersmanual wrote:
Fizz wrote:
Another vote here for Netgear.
At first I was disappointed then I moved it around till I found the sweet spot for it in the house. Now I get a strong signal all over.
I do not agree with you when you say "it slows down the download/upload speeds by a lot". "Alot" is an over statement. Regardless if one needs WiFi range extended then such a device will do the job. I've installe over a dozen of such devices for various people over the last year or so and all were very please with the WiFi extension and WiFi operation post install. - FizzExplorer
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
