Bill_Satellite
Nov 02, 2015Explorer II
You will want to be a DirecTV customer if you want to use that antenna. All of the DirecTV SD programming comes from only 1 satellite while Dish uses 3 satellites so you will have issues with the programming. The 4600 has only 1 LNB so can only "see" 1 satellite at a time. There is no upgrade option so if you want more you would need to replace that antenna with either a roof mounted automatic ($$$) or a ground based antenna either portable automatic ($$) or tripod based manual antenna ($).
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
