wa8yxm
Apr 05, 2020Explorer III
11.6 is plenty. in addition to the coax loss you have between 0.1 and likely 1/2 volt loss in the switch. possibly more but I'm guessing 1/2 THIS IS A GUESS.
Now if the coax is not waterlogged there should be ZERO voltage loss in the coax when testing with a meter if there is any noticable difference between the jack on the Sensar Pro and the antenna end of the coax you have bad coax.
Why is this? VOltage loss is caused by resistance.. Since there is no load, (other than the very high impedance/resistance meter) there is effectively NO LOAD. and thus no current so if you were to take say a 10K ohm Resistor and hook one end to your 12.9 Volt source. You would measure 12.9 on the other end too. but if you added a small load you'd get next to nothing.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
