joebedford
Apr 06, 2020Nomad III
I put the original Jensen wall plate in to see if it worked any better and that's what was there when I took the voltage readings. When I took the 12.6V reading at the plate, I used a 2 foot coax jumper I had lying around.
I could put the Sensar Pro plate back in and I probably will but I'm really thinking I need to get up there and check the connectors in the coax.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
