wa8yxm
Jun 18, 2016Explorer III
drmopar wrote:
Winegard Sensar III option for adding the Wingman antenna looks easy to install. Has anyone installed this and did it help? The Sensar IV is a Sensar III with the additional antenna. Both digital ready.
Two questions, One answer YES (To both)
Just about doubled the strength of UHF stations (no effect on VHF) when I tested it... That's per my TV.. It basically brings the UHF performance of the antenna up to the VHF performance level (Range of reception.
ONe negative.. W/o the antenna is bi directional so if the station is located in the direction you can NOT aim you can point away and peak it.
The Wingman makes it mono-directional.. Front only But simply moving the RV so it is angled a few degrees overcomes this.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
