amandasgramma's avatar
May 27, 2016
Wineguard pathway x2 question
Hi all...need some info. We bought a Wineguard pathway x2 so we could watch 2 separate channels on 2 tvs (Dish)..after having for a month, hubby hooked up the 2nd tv. We aren't getting the normal sats..110, 119 and 127 on EITHER TV. Instead we get sat 72...we lost a lot of the regular shows we watch!!! Anyone else experience this?
  • This pathway x2 is SUPPOSED to be able to point at all 3 and get 2 diff sats at same time on 2 tvs............it has 2 lnbs...at least that is what we were told. BUT...it loses channels on BOTH tvs. I'll try to figure out the EA or WA (Iirc)
  • You can set the Pathway for EA or WA (IIRC). WA will give you 110, 119 and 129 which it sounds like what you are hoping for. You will not be able to watch 2 different channels if they are on 2 different satellites as the dome antennas contain only 1 LNB and can point toward only 1 at a time of the 3 Dish satellites.
