pianotuna
Mar 04, 2019Nomad III
Hi,
I don't think it. I know it. Almost all battery capacity devices require you to set the amp-hour value of the capacity.
However, capacity is a "moveable feast". I.E. a battery at -30 has a heck of a lot less capacity than one at 25 C.
A battery that is 5 years old may almost certainly have a different capacity than a brand spanking new one.
A battery that has had 25 cycles to 50% may have greater capacity than a brand new one.
How is the gauge going to "take care" of all those factors?
The Victron gauge is certainly better than the trimetric (for example), but you still have to guess at capacity.
babock wrote:pianotuna wrote:And you think that why? If you program in the Peukert constant like the Victron has, you can be very accurate. The % of SOC may not be accurate as that is a moving number but the amps removed is very accurate.
With respect,
Amp-hour counters don't give an accurate level. They are better than a volt meter.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
