blackcows wrote:
Kayteg1 wrote:
Good inverter/charger will do the same job while also taking good care about your battery.
When I had Xantex in motorhome, I could pull shore plug and the TV would not even blink.
Trying to think through this in my head. How would I go about doing this? I would need to get 12 volt near the tv?
Inverter/chargers do have automatic switch-over.
You put the box close to battery to avoid long cables, hook up shore power to it on one end and RV 120 fuse box to the other end.
This makes "set and forget" setup.
Each time you plug the shore power, after few seconds the unit will switch over and will automatically top up the batteries.
When shore power dies, the switch in nanosecond switches to inverter power.
This way you have uninterrupted 120V no matter what as long as batteries hold charge.
The system also helps in starting AC having small generator.
That would take good battery bank and bigger unit, but you start AC on inverter power and once it is running - let it switch to generator power, thus avoiding the hassle of hard AC starting on generator.
Unlike generators - inverters have huge peak power ratings.
