opnspaces
May 31, 2020Navigator III
the minimum ratio will work, but it might need to soak for a long time. If you increase the ratio you cut the soak time. For instance my Jayco manual says take the tank capacity and multiply by .13. So my tank needs 5.2 oz of bleach. 40*.13=5.2
That will take 4 hours to disinfect. However if I double the bleach to 10.4 oz. My soak time goes down to 1 hour.
To add the bleach I hook the water hose to the trailer tank. Then I pour 1cup bleach into the faucet end of the hose and screw it onto the spigot. turn on the water and let the tank fill.
If I go with the standard 1/4 cup per 10 gallons I would add one cup (8oz) to my 40 gallon tank. This makes a stronger solution than the minimum (5.2 oz) without being so strong it damages the internal components. So most people will just take the easy route of saying 1/4 cup per 10 gallons over 4 hours.
Below is the excerpt from my owners manual.
Sanitizing the Potable Water System
WARNING: Failure to sanitize the potable water system could result in
death or serious illness.
1. Use one of the following methods to determine the amount of common household
bleach needed to sanitize the tank.
Multiply “gallons of tank capacity” by 0.13; the result is the ounces of bleach
Multiply “liters of tank capacity” by 1.0; the result is the milliliters of bleach
2. Mix the proper amount of bleach into a container of water.
3. Pour the solution (water/bleach) into the tank and fill the tank with potable water.
4. Open all faucets (Hot and Cold) allowing the water to run until the distinct odor of
chlorine is detected.
5. The standard solution must have four (4) hours of contact time to disinfect
completely. Doubling the solution concentration allows for contact time of one (1)
hour.
6. When the contact time is completed, drain the tank. Refill with potable water and
purge the plumbing of all sanitizing solution.
If there is a problem of excessive chlorine odor and taste after the sanitizing process, follow
the above procedures using a solution of baking soda (1/2 cup added to one gallon (4 liters)
of water per 15 gallons (60 liters) of tank capacity) or vinegar (one quart added to five
gallons (20 liters) of water per 15 gallons (60 liters) of tank capacity.)
Your demand water system is now ready for use. Refer to instructions on filling the tank
and utilizing the system in the “Setting Up Camp...” chapter
hour.
About RV Newbies
