luberhill's avatar
luberhill
? help on used MH
Ok looking at a 2002 Fleetwood, 30ft, 18k miles,,,very nice shape...has the v10 Ford engine,,,many upgraded items,,,here's my /'s
1) should I be concerned about this engine with the sparkplug issues etc ?
2) there are 2 coach batteries but,,,you cant use the tv unless plugged into shore power or generator is on, shouldn't it run off the coach batteries ?
3) got all new tires and upgraded steering...led lights inside...no signs of delam or leaks...
wants 20k for it,,,,thoughts ?
  • Spark plug issue 2004 and later
    http://www.expertswrite.net/ford-5-4l-triton-3valve/5-4l-triton-spark-plug-removal.html#
    Some info on 2002:
    http://www.fordproblems.com/trends/triton-engine/spark-plug-ejection.shtml
  • Get a 12v TV. Go to Best Buy, look at the Insignia brand, they have a 120v cord that supplies a power supply brick in the cord (like a laptop computer does) and then the cord plugs into the TV. Look at the TV specs on the back, it is 12v. You cut the cord a few inches from the TV and splice appropriate cord to it to connect to your 12v system (with a switch, the TV will have a vampire current draw). This is much more efficient than running an inverter just to view the TV.
    Charles
    2007 Winnebago View 523H on a 2006 Dodge (Daimler-Chrysler aka Mercedes) Sprinter 3500 chassis (T1N). Bought Sept 2015 with 18K miles on it, Prog Ind HW30C, Prog Dymanics PD4645, Chill Grille, PML/Yourcovers.com deep alum trans pan, AutoMeter 8558 trans temp gauge, Roadmaster sway bar, Fantastic Ultra Breeze hood, added OEM parabolic mirrors and RH aspherical mirror.
