luberhill's avatar
luberhill
? help on used MH
Ok looking at a 2002 Fleetwood, 30ft, 18k miles,,,very nice shape...has the v10 Ford engine,,,many upgraded items,,,here's my /'s
1) should I be concerned about this engine with the sparkplug issues etc ?
2) there are 2 coach batteries but,,,you cant use the tv unless plugged into shore power or generator is on, shouldn't it run off the coach batteries ?
3) got all new tires and upgraded steering...led lights inside...no signs of delam or leaks...
wants 20k for it,,,,thoughts ?
  • how do you know it has "all new tires"
    There could be an inverter that needs to be turned on for tv to work without shore/genny power.
    good post about the spark plug problem and fix at
    http://www.ford-trucks.com/forums/929820-puking-up-spark-plugs-spark-plug-blowouts.html
    if it the one in Sodus it looks nice
  • I don't know about the V10 Ford or the value of the coach but the TV usually operates off 120vac. If you want to run it off the 12v, you will need an inverter.
