Grit_dog
Sep 18, 2019Trailblazer
dodge guy wrote:camperdave wrote:
Yes, this is a big project. You'll most likely end up removing both engine and trans and replacing everything cooling related. God only knows what else you'll find wrong in there lol.
No it’s not. Removing the trans on a Dodge van is as simple as it comes. If it takes more than 3 hours to do the job completely then you must have taken a lunch break.
Camperdave, you’re mistaken. It’s one of the other. Obvious you haven’t worked on vehicles just like the OP. So in that respect, you’re correct that for someone who hasn’t done it before, it’s pretty major surgery. Deciding which piece is best to remove depends on what else needs to be done. Trans is easier. Even more so in a van chassis
I’d probably light a match to an old van before removing the engine...
About RV Newbies
