Zander48's avatar
Zander48
1977 Dodge Sportsman
I'm thinking of buying the above mentioned RV, but it's only problem is I have to change the flywheel. Is this a big project? It has the 360 in it.
  • Pulling a trans is very easy on a lift. On the ground it's a hassle but can be done. Either way on an old vehicle ere is a lot of room under there.
    Why do they say it need a "flywheel"?
  • If you have to ask, it’s a big project.
    Even if you know what you’re doing it’s a big project. Drop the trans or pull the engine, your pick.
    And it’s only a flywheel if it has a manual trans. If it’s an auto, it’s a flexplate.
  • There is a long running thread on Dodge Based RVs you might ask there a lot of Dodge guys may be of help to you.
    CLICK HERE
