Opie431 wrote:
You will have some useless information about it if the original owners did not throw it away in disgust. Get a notebook and begin to run off information from here that you think will help.
You will have to winterize so look for information on that right away.
A list of all the things you have to do when you set up and when you leave is also a good idea.
Do not think that you can use pull the information from your computer when you need it. Have it printed out.
A log book of some sort is a great idea! thanks for that tip.
One question, If I use this TT during the cold months of winter, say go for a weekend fishing, then it would be prudent to re- winterize it after each use? Or will I 'freeze up even while camping in it. though about getting a Buddie heater for the times I m camping without a 50amp supply, just enough heat to keep it above freeing? Thoughts.
BTW In North Texas we can have winter weather in the teens' but the averages are much warmer, I think last winter we had somewhere like 15-20 days below 32*
I appreciate you're patience and I understand how newbies seem to always have rhetorical questions:D
