westernaccents wrote:
tenbear wrote:
Another thought: If you are planning on doing much off the grid camping, check what kind of converter you have. If it is a single stage converter, such as a Magnetek or Parallax 7300 series or older, think seriously about replacing it with a modern 3 or 4 stage converter.
The single stage converters sit at 13.8 volts and this results in a very slow charge rate, and then when the battery is charged it boils the water in the battery away.
I have the paperwork for a inteli power 9200, dont know which model since I haven't located the converter yet.
The 9200 series are good converters, you should be all set.
