Boon_Docker
Aug 25, 2016Explorer III
Look for a valve inside on the city water supply line and close it if there is one. My trailer has a valve like that and needs to be closed when using the pump.
Also make sure your fresh water holding tank is full so the pump will get an initial prime.
How did you test the pump?
About RV Newbies
