mikebreeze
Jan 28, 2014Explorer
I believe that I remember seeing that the Equinox can be towed 4 down in the 2013 Motorhome Magazine Towing Guide. However, you have to start the engine, place the shifter in all gears with N being the last, place the key in the acc mode (so that the engine is off but the wheels turn) and then remove the IGN fuse from the fuse box under the hood. Then the Eak is ready to be towed. This procedure has to be repeated every 8 hours.
I have a 2006 Saturn Vue which utilizes the same procedure.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
