Second_Chance
May 30, 2018Explorer II
The fan(s) on the back of evaporative RV friges is (are) thermostatically controlled and will run whenever the temp of the cooling unit reaches a certain level. If the frig is in a slide, the fan(s) will run more than if the frig is not in a slide. This is due to venting straight up in a non-slide frig. What you are describing sounds perfectly normal.
Rob
Rob
About RV Newbies
