Paulx
Apr 10, 2014Explorer
7-pin plug compatibility
Hello, first post here.
I am kinda scratching my head over these plugs. They seem to be almost compatible, but not quite. Are all the blade type 7-pin connectors supposed to be compatible, or is there some matrix somewhere showing what works with what?
My trailer is a 2014 Salem 18'; it has a connector with blades split in the middle (that is, the pins are female), but the center is round. It says "Bargman". The truck is a 2014 Ram 1500 that has a connector already installed with blades that are folded. It says "Delphi" on the side. They don't seem to connect properly. Am I supposed to push harder, or what? Just by looking, it seems the folded blades of the Delphi are too thick to fit the split opening of the Bargman blades.
