enblethen
Apr 16, 2016Nomad
Is this the unit you have?
LCI manual
First thing I would do if it is like yours, is to disconnect the battery and control wire from the pump. If the control wire is under the same crimp connection and the circuit breaker still trips, separate it.
Now you should know whether it is in the motor solenoid, the control wire or between the battery and the motor solenoid.
LCI manual
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
