TucsonJim
Feb 18, 2014Explorer II
Hi Gillkid - I see this is your very first post, so welcome to the forum! You'll get lots of different opinions here, so you have to weigh the posts with some caution.
There are two primary things to consider when matching a tow vehicle (TV) to a travel trailer (TT).
1. Towing Capacity - Most manufacturers list towing capacity of a vehicle. To be safe, you're fully loaded TT should not weigh more than the towing capacity of the TV.
2. Payload Capacity - TVs also list the payload capacity. Usually you can find the payload capacity on the tire placard that is in the door pilar of your TV. Let's say it's 1200 pounds. The payload you add to the vehicle consists of the weight of the passengers, cargo and hitch weight of the trailer. If the passengers weigh 500 pounds (combined), luggage and other cargo is 300, that leaves you 400 pounds for the hitch weight.
Happy trails to you.
Jim - Tucson
You should not exceed the towing or payload capacity of your TV in order to be safe.
Jim - Tucson
About RV Newbies
