6_7_tow_rig
Feb 19, 2014Explorer
Depending on options your payload on the truck will be anywhere from 1100 to 1580 from what I can find. It looks like the only trailer on Heartlands website with a 4900 lb dry weight was TR sle 25. The hitch weight empty was 500lbs with NOTHING on it. So once you add propane tanks, batteries, hitch equipment and also that appears to be where your front storage is, you will be pretty heavy. Your payload will be gone before you ever put anything in the bed of the truck assuming you would put something in it. The max loaded weight of the trailer is above your max towing capacity. Some things to consider. That will be alot/too much trailer for that truck. You have to remember too that year was before Toyota came out with the 5.7. I think they still had 4.7 which is a good engine but lacks the power of the newer 5.7.
About RV Newbies
