patperry2766
Mar 23, 2014Explorer II
Ford's have three different rear end options:
1.Open rear end where only one wheel has traction
2.Limited-slip rear end that will transfer some power to the non slipping wheel,
requires no driver input (aka..posi-trac, etc)
3. Electronic locking rear end. Operates as a open rear end until the driver manually engages the locking rear end from the dash. When engaged, both wheels turn at the same speed, essentially "locking them" together. There are a few slight differences between 2WD & 4WD regarding when and at what speed the ELD can be engaged and automatically engaged. pg 225 2013 Ford F-150 owner's manual.(locker rear end) REQUIRES DRIVER'S INPUT
About RV Newbies
