DownTheAvenue
May 14, 2016Explorer
Old-Biscuit wrote:DownTheAvenue wrote:Old-Biscuit wrote:
MAX COOL.....
Just means uses High Fan Speed vs Low Fan Speed
Low air flow
Dirty evap coil
Dirty return filter
High Humidity
All conditions that will cause a perfectly functioning A/C Unit to Ice Up
The #1 reason A/C units ice up is low on freon!
Let me point out something for you in my post
......cause a perfectly functioning A/C Unit to Ice Up
That and the fact that OP has a NEW RV.......isn't actually 'icing up'
but was questioning statement by RV Tech to use MAX COOL
Comprehension/reading
And YES low freon will cause icing up-------hardly a perfectly functioning unit
Aren't we a little grouchy?
Nothing changes the post I made. An icing up air conditioner is usually low on freon.
And by the way, with my advanced, post graduate degrees, I am quite adept at reading comprehension, which is the term you were trying for when you typed, "Comprehension/reading."
No need to be so sensitive!
About RV Newbies
